This tutorial is for adapting an OIL COOLER for a vehicle equiped with a front mount intercooler. Mounting an oil cooler on a naturally aspirated vehicle would be less involved than this install.I used a STILLEN OIL COOLER KIT which I purchased for about $380.The kit is designed for a N/A vehicle and WILL NOT fit in the designed spot and the following tutorial cover the modified install. This kit is a bit pricey and you can put together a kit for far less,I got really beat on the deal by STILLEN but made do with what I had.You will need the following tools:
floor jack
jack stands
basic tool set
fine tooth mini saw
cordless drill
drill bit
6 qts oil
oil filter
floor jack
jack stands
basic tool set
fine tooth mini saw
cordless drill
drill bit
6 qts oil
oil filter
