1 - 20 of 26 Posts
Full Interior LED Kit - Nissan 350z
At Diode Dynamics, we carry a full line of LED bulbs, to replace your map lights, license plate lights, vanity lights, trunk light, turn signals, fog lights, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Our LED Conversion Kits include all of the LED bulbs you need to replace the incandescent bulbs in your vehicle, for interior and license locations. It has been tested in your specific vehicle, for perfect fitment, and no guesswork! No modification is required for installation, you simply replace the bulbs!
We are pleased to offer these LEDs in a truly customized way. You can create the kit that you prefer. Simply change the quantity to "0" for any bulbs that you do not wish to purchase.
By using the ordering options on this page, you can create your own mix-and-match kit by making the proper selections on each stage, or choose one whole kit that you prefer. The product pictures are professionally taken, at the same camera settings, in order to provide an accurate idea of what the bulbs will look like, in terms of brightness compared to the factory bulbs.
Brightness. We offer three levels of brightness, or "stages." All stages will provide a sharp, modern LED look, and all include the same number of bulbs. Please be sure to read all of the following information:
  • Stage 1: Near factory brightness.
  • Stage 2: Slightly brighter than factory.
  • Stage 3: Much brighter than factory.
  • Stage 4 Flexlight: (Trunk only) This is a flexible LED strip with connector, for plug-and-play installation. It replaces your factory trunk light, and can be positioned anywhere you would like, with included velcro and adhesive.
All brightness levels are for general reference only, and apply only to the use of white LEDs. Please see the note below regarding the use of colored LEDs.
Please note that the stage 3 trunk light is often an LED board, which must be installed directly on top of the trunk light housing to achieve maximum brightness. All other lights will fit inside of the light housing with no modification. Some stage 3 interior lights use direct-replacement adapters with an LED board for maximum brightness.
Color. White is our most popular color. It is a 6000K cool LED white. We also offer yellow, green, blue, and red, at no additional charge. When making your color selections, please bear in mind that white projects the most usable light, so white will appear brighter than the same stage of a colored bulb, usually by one stage difference. For example, a red stage 3 light will have a similar usable light output as a stage 2 white light.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
CLICK HERE FOR MORE INFO OR TO ORDER!
Questions? Post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
Diode Dynamics
Customer Reviews:
"These are the best LEDs you can buy. Top notch quality, lit up my Z very nicely. Always get the stage 3 LEDs when ordering. I have used these in many cars and they have all worked flawlessly!" (Posted on June 18, 2013)
"Got the city, map, trunk and license plate lights, such an easy and cheap mod and it makes everything look 100x better. Great product and fast shipping too." (Posted on May 21, 2013)
"Just installed this on my 350z. I purchased the stage 3 red led map lights. It LITERALLY took 5 minutes to replace both map lights. Very simple and the lights turned out AWESOME. stage 3 for red is what you want since it is bright enough to light up the entire interior." (Posted on October 25, 2013)
"This light is amazingly bright and clear! Got the LED and installed it at night. I could not believe the difference in light offered by this simple modification!" (Posted on July 14, 2013)
"Bought the stage 3 and couldn't be happier. Much better than stock, and I highly recommend stage 3 for the best lighting possible." (Posted on June 18, 2013)
"I was looking for some brighter lights for my '06 350Z Roadster. I'd already bought the LED license plate lights that work really well so I shopped diode dynamics again. Great price, fast delivery super easy to install and they work fantastic. Clear, white and bright light. I recommend them to everyone!" (Posted on January 24, 2014)
"Just installed this on my 350z. I purchased the stage 3 red led map lights. It LITERALLY took 5 minutes to replace both map lights. Very simple and the lights turned out AWESOME. stage 3 for red is what you want since it is bright enough to light up the entire interior but doesn't blind you." (Posted on October 25, 2013)
"I highly recommend the stage 2 set. These definitely make the interior look great and are easy on the eyes. In my opinion, these are the best because they're definitely brighter than the stock bulbs, but not so bright that it blinding. Overall, I'm pleased with the look inside and from outside the car!" (Posted on July 9, 2013)
I have a issue with front led turn signals. On a 2008 Z, my has three wires but other forums say front signals only have 2 wires. HELP!!!!!
The newer Z's have a dual-filament front turn signal. One of those wires is for the running light portion of the bulb, the other is a signal wire, and finally, there should be a ground wire.
If you need more wiring information, please send an email to: [email protected] and we can assist you.
Make sure you install the resistors correctly. They should get hot during turn signal use, that's how you know they are creating electrical resistance
Thanks!
Nick C.
Discussion Starter #5
I just love the internal lights, they give the car a whole new feel. I shall be placing an order soon.
It's a simple upgrade that makes a huge difference in the appearance of your Z at night!
Don't forget to send us a PM for the free-shipping code (U.S. members only)
Thanks,
Nick C.
Discussion Starter #13
A common question we are asked about our SMD12 model option, "will it fit inside the housing with the lens cover on?"
Bulb dimensions are being added to our listings to help customers confirm fitment for unique applications.
Thanks!
1 - 20 of 26 Posts
