1 - 14 of 14 Posts
Nissan 350Z Front & Rear Turn Signal LEDs! Get modern looks! See Installed Photos!
Nissan 350Z Turn Signal LED Bulbs
Diode Dynamics LED replacements shown on an Infiniti G37- as you can see, a much more modern, precise look!
7440 27-5050 SMD LED Bulb is a direct replacement for any 7440-size turn signal bulb. This bulb has 27 5050-size SMDs. It uses an 7440-size terminal and will fit as a replacement for stock halogen. It uses less power and heat than halogen bulbs, and will last longer, with its engineered heat-sinking technology. A load resistor is embedded to prevent blowing the LED from voltage surge, and a diode is implanted to protect the LED from reverse polarity. The LED is wired for 12v operation, the kind found on all vehicles.
The advantage of LED turn signals, when compared to your stock bulbs, is that these are instant-on and -off, for a very crisp, modern look. Additionally, these are red in color, and make the OEM bulbs look orange by comparison. A nice, true, red turn signal, with that modern look of LED!
Resistor Option: The Nissan 350Z will have fast-blinking when LED bulbs are installed as turn signal replacements. Diode Dynamics offers resistors to remedy this issue for a nominal charge.
Diode Dynamics carries the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs designed by our engineering team here in St. Louis, and every bulb carries with it a 3-year limited warranty.
2006-2009 Nissan 350Z FRONT
2003-2005 Nissan 350Z FRONT
2003-2009 Nissan 350Z REAR
Here's an example of the HP24 switchbacks. White when operating as the running light, flashes amber as the turn signal
Amber when the turn signal is activated:
If you have any questions, please don't hesitate to post, PM, email [email protected]
*U.S. Residents PM us for the Free-shipping code!
Thanks for looking!
Nick C.
1 - 14 of 14 Posts
