1 - 2 of 2 Posts
After I had my oil galley fixed, I run my Blue Diver and the car receive a Code: U1000. I don’t notice anything wrong with my car when I’m driving and wanted to see what can cause the issue? The oil galley I swap from the bad one is EPS Tuning Oil Gallery Gasket/Hardware Kit VQ35HR.
FREQUENTLY REPORTED FIX:
• Repaired Evaporative Emission (EVAP) Pressure Sensor Wiring
4 OTHER REPORTED FIXES:
• Replaced Automatic Transmission w/U1001
• Replaced Totally Integrated Power Module (TIPM) w/B2099, B2109, C1131...
• Replaced Transmission Control Module (TCM) w/U1001
• Replaced Unified Meter And A/C Amplifier w/P0462, P0500, P0717...
A U1000 is not a common code for any Z33 to have. Since it's usually a CAN communication error, it's unlikely you'll find many others who've had the same issue. Before you start trying to DIY and replace parts without knowing, why not research and find a Nissan tech in your area with a CONSULT III tool to do the diagnostic? Expect to pay for an hour of shop time to have them do the diagnostic and more if you want them to fix it.
1 - 2 of 2 Posts
