Bonjour, je voudrais changer mes phares d'origines avant de ma Nissan par
Fairlady LED Halo Projecteur Phares Lampes Noir
Est-il possible que fonctionne ? Parce que mes phares HID ont 8 fils et les nouvelles 6 fils
Merci de bien vouloir me renseigner
Lyly
Google French to English translation is
Hello, I would like to change my original front headlights of my Nissan parts
Fairlady LED Halo Projector Headlights Lamps Black
Is it possible that works? Because my HID headlights have 8 wires and the new ones have 6 wires
Thank you for kindly informing me
Lyly
Super Moderator
While I'm no expert of euro-spec parts. six wire headlight connectors are usually for halogen lights. The eight wire connectors are for HID applications. Hope this helps.
Google English to French translation:
Bien que je ne sois pas un expert des pièces euro-spec. six connecteurs de phares à fil sont généralement pour les lampes halogènes. Les huit connecteurs de fil sont destinés aux applications HID. J’espère que cela vous aidera.
I would say you're asking for unnecessary trouble. No guarantee but the voltage drop from going FROM factory 8-pin BiXenon lamps to LED can cause the car's ECM to read the voltage drop as a fault in the system. Most common is a U1000 CAN error. I'm sure there are others that have done this without an issue but you should at least know of potential issues. (I would hope the lighting manufacturer took this into account and installed the necessary resistors or other circuitry to negate this as a possible issue.)
If you have 8-pin connectors (existing HID), the 2006+ BiXenon headlamps are far better than anything else you can buy. And there are ways to increase output by swapping out lenses, uprating ballasts and bulbs.
Original equipment/Replacement BiXenon lamps are not cheap but there is an option: Depo (brand) '06+ BiXenon replacements.
Above via Google Translate (hope nothing gets lost in translation :rolleyes:):
Je dirais que vous demandez des ennuis inutiles. Aucune garantie, mais la chute de tension du passage des lampes BiXenon à 8 broches d'usine à la LED peut amener l'ECM de la voiture à lire la chute de tension comme un défaut dans le système. Le plus courant est une erreur CAN U1000. Je suis sûr qu'il y en a d'autres qui l'ont fait sans problème, mais vous devriez au moins connaître les problèmes potentiels. (J'espère que le fabricant d'éclairage en a tenu compte et a installé les résistances nécessaires ou d'autres circuits pour nier cela comme un problème possible.)
Si vous avez des connecteurs à 8 broches (HID existants), les phares BiXenon 2006+ sont bien meilleurs que tout ce que vous pouvez acheter. Et il existe des moyens d'augmenter le rendement en remplaçant les lentilles, en améliorant les ballasts et les ampoules.
Les lampes BiXenon d'équipement d'origine/de remplacement ne sont pas bon marché, mais il existe une option : Remplacements Depo (marque) '06+ BiXenon.
Ceci est un revendeur américain:
