After searching for days, I've found the rims I want (not telling until they're on!).
My question - for one of our tire/rim brothers is: the rims only come in 18x10 size. Will they fit my '05 Enthusiast?
Second part: most of the rims I've looked at are not compatible witht the TPMS on the Z. Are there any consequences if we install tires/rims that don't contain the sensors?
Thanks. :cheers:
The rim will fit on your car as long as the lug pattern is correct. I am currently running 19x10.5 in the rear.
Secondly, you will be fine if you drive your car without the TPS on. The only thing that will happen is that your car will show dash lines instead of reading the tire pressures. Some people have banded the TPS onto the new rims but, this makes the wheel harder to balance and it really isn't needed. You will be fine without your TPS, just keep them in your stock rims and save those as backups.
Originally posted by lionkiller@Aug 11 2005, 11:04 AM
a 10" wheel in front?.....who's running that?....be sure to check offsets.
[snapback]144563[/snapback]​
Thanks for the feedback.
Looks like I'm going to go with 18's.
