hi guy
i boguht some SMD interior light want change small light under door light (when u open door light will turn on)
i took off stock and fit that on it not work
i try put back stock light blub on and not work too
is some problem with fuse on light?
i try find fuse box there 1 under boonet but is there other fuse box too?
oh and
can V35 fit in double din dvd unit in car?
cheers
Hi,
The 350z already has a double din headunit in the Bose. You take that out and put in a new head unit that contains a DVD playback feaatures.
If you go with a new single din head unit, then you can have either extra storage space underneath the head unit, or mount the head unit in the lower din space and have a screen in the upper din space.
I hope that helped
the V35 is Infinity G35 in the USA
there are 3 fuse boxes
1 under the steering wheel on the right side under the dash
2 in front of the battery
3 behind the battery to the left near the left quarter panel
the one you are looking for is behind the battery
To get to that one you need to pop the battery cover by removing the plastic clips then once this is done Just pop the pin of the plastic cover for the left wiper blade off
have a read of this threadV35 Coupe Fuse Box With Pics - Skylines Australia
here is a picture of the fuse box http://www.skylinesaustralia.com/forums/post-a306074-
