every 36 months or 45,000 miles, whichever comes first
no filter that i know of, this is from the service manual for a M/T
Replacement
DRAINING
1. Start the engine and warm up the transmission unit sufficiently.
2. Stop the engine, remove filler plug and drain plug and then drain fluid.
3. Set a new gasket on drain plug and install it to the transmission.
CAUTION:
Gaskets are not reusable. Never reuse them.
FILLING
1. Remove filler plug. Fill new oil into the transmission to the level of the filler plug mounting hole.
2. After filling, check fluid level, Set a new gasket on filler plug and install it to the transmission.
CAUTION:
Checking ACS0015J
OIL LEAKAGE AND OIL LEVEL
Check if oil is leaking from transmission or around it.
Check oil level from filler plug mounting hole as shown in the figure.
CAUTION:
Never start engine while checking oil level.
CAUTION:
