1 - 14 of 14 Posts
ok... i had my front license plate off from when i bought my car in FEB '04 until Jan '05 and finally got a ticket for it.. (parked relatively close to a Police station).. since then. i have repeatedly heard that it is now legal in CA to have it off.. can anyone verify?
after doing a quick search on google.. I find no evidence that you are not required to have a front plate.
This is just a "fix it" warning isn't it? Or is it a fine and no points?
There is a petition for it:
http://www.petitiononline.com/caplate/petition.html
And also some funny reading.. maybe you aren't high enough a profile or you could remove your plates all together (and replace with a bar code?)...
http://www.russellbeattie.com/notebook/1008538.html
Either way.. I'm sure it it wasn't required.. You probably wouldn't have gotten a ticket.. But then again.. It is Nazicali...
Seems like you lasted a while without it. Maybe you can try again and beat 11 months.. It was almost a year... that should get you some sort of merit badge. :)
EDIT!! :) http://www.dmv.ca.gov/pubs/vctop/d03/vc5205.htm
Look at that ^^^ You can have stickers in lieu of the plate(s)!!
Have a look on the CA DMV page.. http://www.dmv.ca.gov <=------ Your answer lies here!! Search ON! Fight the powa!!
You are required to have a front plate in CA. That section Chris found is very ambiguous. Saying the dept. MAY blah blah but it's not law. You can take your chances, and maybe not get another ticket. Why not get the bracket that you can attach to the grill and put it there instead of drilling??
One thing I like about living in PA........no front plates. You are only issued one plate and can't get a second one if you wanted to :lol:
My '72 Jag doesn't have a front plate, either....That's TWO without front plates....I know...DMV blahblahblah...
When they do pull me over, I'll be sure to ask about code sec. 5205....
I haven't lived in CA for several years but front plate was required back when.
NJ requires both plates, but a nice frame makes it liveable!
directly from the ca vehicle code {link}
5200. (a) When two license plates are issued by the department for use upon a vehicle, they shall be attached to the vehicle for which they were issued, one in the front and the other in the rear.
5201. License plates shall at all times be securely fastened to the vehicle for which they are issued so as to prevent the plates from swinging, shall be mounted in a position so as to be clearly visible, and shall be maintained in a condition so as to be clearly legible. The rear license plate shall be mounted not less than 12 inches nor more than 60 inches from the ground, and the front license plate shall be mounted not more than 60 inches from the ground, except as follows: ...
1 - 14 of 14 Posts
