1 - 18 of 18 Posts
Hello there,
My first post and had a question about lambo door kits, I'm debating whether to put them on, I actually already bought them but every local body shop seem to discourage me. Has anyone here put them on? Are they a pain? is it worth it? Do the fenders have to be rolled?
Any xtra pointers are greatly appreciated
Thanks and Nice Forum :irock:
Well depends upon what you use your car for. If you are showing it, then it's def. nice to have them. If it's a daily driver, then it's a toss up. I've heard they are a PITA if you are using the car everyday. Also heard that some of the brands hydrolics can get weaker in the cold, or just plain fail. Also heard of some fitment issues. I don't think you have to roll the fenders tho.
Heard that it weakens ever so slightly and you would need to adjust it to fit it right every few weeks. And also, I've heard that you would need to actually stand up partially to pull it upwards, can't do it while sitting down. Haven't really heard anything good about it except the attention it gets.
Exactly. Daily Driver = PITA Show car=lookeloo points.
Thanks, I appreciate the heads up. Prolly won't put them on since I am a daily driver and do not want the headaches...
Thanks
I've seen it on a couple of Z's. They do work, and I haven't heard of any problems if they installed it correctly.
In my opinion.. this mod should only be done if expense is no option.
Look at the link from the other forum... There is a crap load of labour involved in making that kit right. I wouldn't want my door hanging above my head or passengers, If I didn't 100% know it was installed and the parts were top quality.
One more thing.. lambo doors don't permit the range of entry access you once had with conventional doors. Translation: if your big, or have any big friends, you're/they're not gonna fit in the Z. The doors only go up about 45 degrees. They pitch away from the car at about 20 degrees. You have to sneak in behind the doors to get in.
1 - 18 of 18 Posts
