Hi guys,
I have a base Z and am looking for wheels. Found some 19" Konig Unknown wheels and am not sure what offset I would need or if they will be ok. The front come in 19x8 with 30 offset or 19x8 with 34 offset, and the rear are 19x9.5 with 40 offset. What front wheels should I use and will these wheels be okay on my Z?
Thanx
jdm299
stock performance 18s are 8" wide +30 offset.
stock 17s are 7.5" front +30, 8" rear, +33
track rays are 8" +30 front 9.5" +33 rear
play with this website:
http://www.1010tires.com/WheelOffsetCalculator.asp
A little less offset would look optimal., but the +30 front and +40 rear will work just fine, as the fronts will be the same place as stock and rears stick out 9mm farther.
For comparison, I'm running 8" wide front +21 and 10" wide rear +28 and they are right to the edge of the wheel wells.
Okay I see how it works, wasnt too sure about the offset and what the differences were but I got it now. The link helped, thank you! I like the wheels but not too sure about them now.
Thanx
