So I tried looking up the blinking pattern in the FSM but it wasn't in there...?
I did a repair on my car recently. Had to drop the tranny and adjust the clutch pedal so I may have done something to the wiring.
I want to know where to start but the diagnostic code isn't even in the FSM??
Pattern after "On for 7 seconds" is as follows:
On for 3 seconds (pause 2 seconds)
Two flashes (pause 2 seconds)
Repeat
The only similar one I found in the FSM is { 3 seconds ON, 2 flashes, repeat }... am I meant to ignore the second set of flashes? PLZ HELP!! ?
Discussion Starter #2
UPDATE:
The light is still flashing, but is no longer a pattern. Just on off flashing constantly..
Super Moderator
Get a OBD2 code reader and pull any codes held in memory, particularly in the BCM section. The codes should tell you what the onboard diagnostic system is detecting.
Discussion Starter #4
Thanks for the reply.
Realized my steering wheel horn switch isn't working either, must be the clock spring.
... also didn't realize I was supposed to lock the steering wheel when I removed my column lower joint? oops, there goes $200 ?
Codes came up as:
B1049 / B1054 - Driver Air Bag Module Open
B1134 - Left Right Side Air Bag Module Open
For what it's worth, SRS codes are not stored in the BCM, but are recorded in the Air Bag Diagnosis Sensor Unit.
