i just installed the Motordyne intake spacer kit today. when i started it up, it ran fine, but as it warmed up the idle got rough. i didn't throw any codes, but it's bad enough for me to be concerned. my kit came with the double thermal isolators, so i used both (no clearance problems). i also believe i pulled the two center heli-coils on the lower plenum because i heard a snap on both (5ft-lbs equals 60in-lbs, right?). needless to say, i'm not amused with my newly purchased torque wrench. from what it looks like, i should be okay for a seal, at least temporarily until i can get new heli-coils dropped in. i don't see it as being that large of a leak, but then again, i'm no engineer. i didn't hear any air leaks either. if there's any insight into this let me know.
thanks
thanks
