I was wondering if it is completely neccesary to remove the front bumper to install the clear side marker lights? Thanks!
It is possible to install them without removing the bumper by going through the front wheel wells.
Jack up car, remove inner wheel well lining (you may even have to remove the wheel to get in there deep enough).
However, you'll go through just as much trouble doing this as you would removing the front bumper cover. There's got to be a How-To on here somewhere for removing it. Good luck.
Thanks alot everyone for the quick response. :yourock: I will install it by removing the front bumper tomorrow after work.
Removing the front bumper is definitely the way to go if you don't have infant sized hands or have a 90 degree angled screw driver. It was a pain when I did mine for sure. First, I tried without removing the bumper, then realized I couldn't do it without removing it and had to remove it to install the side markers.
Good luck with the install!
