I installed an Injen CAI a while back and it is all installed correctly and could never get a straight answer as to why my cars idle is all messed up. Before I installed it the car was fine then I installed it about 2 days later (I don't drive it much, I have a work car) it started acting up.
Now to top off all of that recently I installed a set of headers and race pipes now the **** check engine light is on and if you rev it way up and let off the car dies. I have heard that this is from cat delete and the computer is trying to retard the timing to fix the emission problem with too much unburned fuel going past the O2 sensor (after cat O2).... so many problems with modding this car its like its ok with being stock.
What I am getting at is WHERE IS THE FIX!? I know back in the day when I had my old vette I did a cat delete and had the same problem and had to put non fouler spark plug extensions in the O2 port to fix the problem but I'm not sure if that will work here and I don't know how this ECU works yet.
I'm open for suggestions…
