We have 3 main units a 900MHz(base) a 1GHZ and a P4(hi-end)Coming Soon
All But the Base unit come with 512MB PC2100 266ddr ram or you can upgrade to 1g of ram. Either a 20g,(optional) 40g or 60g hard drive. A "Smart" power supply that turns the unit on and off with the car (no power button to push) all units come with a Internal DVD-ROM and you can get an optional External USB 2.0 DVD or DVD/CDRW rom to mount else were in the car (like the mailbox slot in the back).
Options Include a "Flex" USB Keyboard or a Zippy mini keyboard with Indiglo back light, RF wireless remote (mouse), Internal, glow in the dark, Neon, a FM modulator (to hook up to the stereo), NAV/GPS receiver and your choice of software(4 to choose from), Integrated XM Radio, And Real time Onboard ODBII EMS**(see below for more info) and all the cables and adapters you need to hook every thing up.
The Screen (on all models But the Base) is a 7" VGA and a touch screen* is available as an option($499).The base unit does not come with a screen.
Right now we are testing Backup Camera, boost Control(for turbos),and PCMCIA support
The retail on the Mid end unit is around $2,500 it comes with 1GHZ cpu 512mb ram, External DVD-ROM, top of the line talking NAV/GPS, 7" VGA, 40g HHD and more.
The Base units start at around $800. All units come with Do it yourself install instructions and a 1 year parts and labor warranty
Operating Systems such as Windows XP will NOT come included due to license fees, but any other options that requires software(such as GPS/NAV) the software will be include (we do recommend using Windows XP)
The unit is a Windows base system and will do anything Desktop or laptop will. you can play PC based games, Word processing, Internet (where available), just about anything you would want a pc to do!!!!! Of course none of that should be done while driving.
The Units Are Designed Especially for the 2003 350Z (without factory NAV) But can Be adapted to other vehicles as well.**2004 350z Models require extra Modification to the Nav area For the Screen to Fit easily**
*Touch screen:
I have heard of several people that have had MAJOR issues with the drivers for the touch screen.That is one of the reasons that if you want this option you should get the screen yourself, so if you have problems Xenarc can help you directly. Also keep in mind the Case of the Xenarc screen has to come off for it to fit in the Z. This may also cause problems with the touch screen. As far a safety goes, it is hard to imagine how small the Icons and buttons are on a 7" screen. I have found it almost impossible to use the touch screen with out using something like a touch pen that you would use on a PDA(my fingers are just to big to "click" what I want to) its hard enough on a 12" touch screen. I think that it would be REALLY Dangerous to try to use a small touch screen while Driving. it would not be to bad to just open the programs via touch, but to use the features of a program(like NAV) could barely be done. So the extra cost is just not justified to me.
** ODBII EMS
The New ODB II add on will read, And log, all the sensors data in the Z. Like Intake Temp, Coolant Temp, MAF in gm/inch, engine Load % , Short and long term Fuel one bank 1 and 2, O2 sensors, Speed, RPMS, and more. It will also Read error codes, tell you what the code means, and allow you to turn off the CEL.
Other Features include measuring 0-60mph times, 1/8 mile times, 1/8 trap speeds, 1/4 miles times and 1/4 trap speeds. It Also has a software based DYNO. You just enter Vehicle Weight, Tire size(like 275), Tire Aspect ratio(like 40), and rim size(like 18), to get HP and Torque #'s From a 3rd gear pull.
It Retails for $150. This includes the ODB II Interface cable, The "BlackBox" Signal processor a serial cable to hook it up to The In Z PC or any other PC like a Laptop.
It is very Easy to hook up as well. Just Connect it to the ODBII port on the Z (its on the left of the steering wheel just under the dash) hook up that cable to the "BlackBox" then hook up the serial cable to the Black box and to the back of the PC. then Install the software and your ready to go.
If you have any other questions feel free to ask,
