1 - 11 of 11 Posts
Hey gang, I have about 100,000 miles already on my 06 and still runs like new. I am looking to replace the ignition coils soon. Any suggestion on after market parts. Also who makes the OEM ignition coils of the Z. I call the local Nissan dealer and they said " NISSAN make those. Thanks in advance. Joe
Yeah, I don't see why you would want to replace the coils. If you have 100k on the plugs, I'd definitely replace those...
well I have not heard of anyone really having major issues with coils, and not many do a routine replacement of them, probably due to the cost, around 100.00 a coil, people usually wait until they fail
So I guess if you want to be safe you can go ahead and do them now, it is tough to say how long they will last.
Discussion Starter #6
I am planning to buy 3 now and 3 three months from now so I would not be a big bent on my wallet. I'll keep the old ones as spare parts. I guess I will stick with OEMs.
There is absolutely no reason to change a coil pack unless it fails. They either work or they don't - there is no "performance fall-off curve" with age. Best to leave well enough alone.
I just wanted to clarify on this a little, because I read this and was slightly mislead, probably just due to my interpretation of it. I read this as a coil pack will either work, or won't work, and not fail intermittently. However I recently had one go bad on my 2003 Z and it was definitely an off-and-on type problem. It would run smoothly from a cold start, and generally things would start misfiring when the engine warmed up, or on the next start if it was not allowed to cool down completely. It was throwing a random misfire code so I couldn't isolate it to one cylinder until I took it to a shop for some diagnostics and they were able to shut down individual cylinders to figure out it was isolated to only one cylinder. I then swapped the coil pack off that cylinder and the problem moved with it. So, I learned that just because you're only misfiring occasionally doesn't mean it's not a coil pack issue. Oh, I also only have about 47K on the engine so it can happen at a relatively low mileage as well.
Sorry for resurrecting an old thread as well but hopefully I've added some value. :thumbsup:
I've seen several Coil Packs gone bad amoung my fellow local Z's.
If you are definate that it's the coil packs, then maybe try "OKADA Plasma". I have been using it for 2 years, and not a single problem. It is smoother through out all RPMs and top end seems to be a little more powerful (according to my butt-dyno).
Remind you that OKADA doesnt run cheap tho... It's definately worth it if your OEM onse gone bad.
Sorry for resurrecting an old thread as well but hopefully I've added some value. ?
Thanks for this info. I have a 2003 350Z that started the multi misfire & it's gotten really bad. I was told to take it to the dealership because they could detect which cylinder it was happening on. Unfortunately the dealer said they did not detect any misfiring & that I needed to replace my right downstream O sensor & the catalytic converter. I did not do that yet, but every other time that I have had the computer checked it is multi misfires, so I guess I'll install new ignition coils before I have any cat converters changed.
Does anybody here know how to check an ignition coil to see if it is bad? I went on ahead & changed all of my ignition coils only to find out that my cats were worn out, so I had them replaced too. You can find out about in another forum here. Anyway, I was wondering if any of those original ignition coils were good? Thank for any help you can give me.
1 - 11 of 11 Posts
