was gonna install the XM/FM modulator, but then after i ripped everything apart and broke a few tabs, i found the modulator should be installed on the radio side, not the antenna side.
Just a warning. If you ever remove those trims, chances are that they will never pop back in the same. Mine is really loose now, so most likely it will rattle like **** and drive me over the wall
