1 - 9 of 9 Posts
Stupid question, I'm new at upgrading and changing things on my baby Z. What is the best way to black out the orange signal lights on the front lower corners?
The ones in the headlights? Most people take apart the ballast and go from there. If you don't like the actual turn signal, then you can remove the bulb. However, you take the risk of getting a ticket for no turn signal.
Welcome to the site, BTW. I moved your thread to the appropriate section.
And if you are talking about the orange "sidemarkers" there are no lights in those.
You can get some pretty sick looking aftermarket clear LEDs lights made to fit in the spot for the markers. They do requiring wiring as the original markers are just a reflector. If your wanting the black look I would say get a heat gun and try to install the pre cut black out tint made for the lights. It's a safer alternative then buying the $10 spay tint can at the store because if you mess it up you can peel it off. Or you can use plastidip. It is a spray paint that dries into a plastic film you can also peel off.
I didnt like mine and I simply removed them completely...
don't like these…nothing says tricked-out-rice-trying-to-be-an-Audi than LED headlights and/or turn signals that didnt come from the factory...
Talking about front side markers/reflectors?
What I did...apply smoke vinyl overlays.Pretty cheap.
Available on ebay.Pre-cut to size.Suggest also doing the rear
white/clear backups with the same material.Plenty of light comes
through the overlays.Looks MUCH better.
1 - 9 of 9 Posts
