1 - 20 of 63 Posts
I finally had a chance to tackle this little project after a lot of procrastinating. When I saw another member post that it was pretty easy and followed some instructions from the site, I decided to try it and take pics. Hopefully, you can follow what I did and save yourself a couple of dollars.
Tools needed or used:
  1. 10mm socket
  2. 12mm socket
  3. flathead screwdriver
  4. phillips head screwdriver
  5. WD40 or another cleaner
  6. air compressor
Also have some rags handy. Your fingers will get greasy from all the gunk inside the door panel. Give yourself plenty of lighting to work with, and take your time. Study what you're looking at and be organized about the project.
First, here's the first thing I undid. It's the screw inside the door 'handle' which will need the flathead and then the Phillips head screwdriver.
Then I started popping off the door panel along the bottom. In hindsight, I could have done things in a different order which I'll post here anyway.
I took out the control panel for the windows, which I left plugged in.
You should pop off the arm rest first. This can be done relatively easily by prying it from the rear (by the back of the door). The reason you have to do this will be evident in the pic.
You need the armrest off to pop that clip to allow the control panel to come out. I used a flathead to push the clip in.
Discussion Starter #2
It took me a while to figure this next step out, so now I'm going to save you some time. There's a small, plastic cover just inside the handle to open the door. Pull the handle back and carefully use a flathead to pop that plastic cover out. This is what you'll see.
I then used a long Phillips head to unscrew the bolt inside that open area. Be careful not to drop the bolt unless you have a magnetic head on that screwdriver. I used needle nose pliers to get it out. Once this is done, the whole panel can come off. The panel is held on by plastic 'clips' along the bottom and sides. When you carefully pop out the panel, the whole thing should be pushed up to slide the panel off the top lip of the door. Then you'll see the inside panel.
Use the 10mm socket to take out the army green screws along the perimeter of the panel. There are also some brass screws in the interior of the panel. Use the 10mm and 12mm socket for those. The 12mm socket takes out the nuts that hold the window rails near the bottom of the panel. Be careful not to rush the panel off. The 3 screws that form a triangle near the middle of the panel is what holds the motor assembly.
Once you pull the panel away from the door, you'll see this.
There's the window motor! I didn't have to unplug anything. No cables or wires or connections were disconnected. Now for the closeup of the motor housing.
I used the Phillips head to unscrew the 3 screws holding the housing down. Don't lose those screws! Pull the housing off, and this is what you'll see. Look at how dirty the base looks just underneath the coil.
I used WD40 and sprayed liberally along the base. I also used a toothbrush to lightly scrub the area under the coil. I forgot to mention that I also have an air compressor, which I used to spray air into the motor unit to push out any debris and excess cleaner. Make sure you have a rag wrapped loosely around the housing area so you don't get overspray.
Now look at how clean and shiny it is compared to the pics above and this closeup.
Discussion Starter #4
After I was satisfied that the motor unit was clean and the WD40 had ample time to evaporate, I used a rag to wipe down the inside of the housing to ensure no contaminants would make its way back to the clean motor. Then I pretty much did everything in reverse order to put it all back together.
I started by putting the window motor assembly back onto the silver panel. That should definitely be the first thing you do when putting the panels back together.
The hardest part for me was getting the silver panel lined up with the window rails and the 2 bolts along the bottom. I had to grab the silver rails (left and right in the pic), push it up and out and get the bolts into the holes in the silver panel
Have those 2 brass nuts handy since you'll need to put them on quickly to hold the panel onto those bolts. Once that's done, you can align the whole silver panel back onto the door and use those army green screws to hold the panel on even better. I screwed them in by hand just to get them all on correctly. Then I tightened them along with the other bolts and nuts.
Remember what I said about being slow and methodical? Just go slowly and remember what you did when taking it apart and you'll be fine when putting it back together. Be sure to use those rags to clean your hands when putting it back together. You'll know what I mean after handling the silver window rails.
Good luck!
QUOTE (SmoothZ @ May 18 2008, 04:24 PM) index.php?act=findpost&pid=528612
The window now works like a charm! :irock:
Hey SmoothZ...
I did this procedure about a week ago... A couple of things:
That piece will actually twist right out of the motor area (the final part that you are cleaning) and once its out its even easier to clean.
Now the bad news...
My window started NOT working again today!
once it was clean, that thing was working every time without problems...
Just today it started not to work!
Not sure what to do next...
NOT HAPPY!
Nice instructions though... anyone with the problems, I suggest trying this first!
CK
i just performed this procedure on my friends 03 350Z. heres some pics of the rotor assembly out and clean.
[attachment=25058:copy1.jpg]
[attachment=25059:copy2.jpg]
[attachment=25060:copy3.jpg]
this is what it should look like for the average rookie. i just wish i had a dremel with a polish wheel
everything worked as advertised once we were finished.
Discussion Starter #9
Well, now that I know I can take that out, I'll have to take apart the door again. I'd rather do that than pay hundreds for a new motor.
QUOTE (SmoothZ @ May 25 2008, 09:16 PM) index.php?act=findpost&pid=530666
thanks for posting this SmoothZ - i did the exact steps and was also able to get my driver's side window working again. Well worth the effort and couldn't have done it without your well written post with pics. Just FYI, there was a step missed in it - after removing the control panel, there are two screws behind it that need to be taken out. after that everything went perfectly.
thanks again!
Discussion Starter #11
Okay, I went ahead and removed the assembly by twisting it out like voodoo suggested. Just keep turning it left until it comes out.
I saw that it was pretty dirty down there, so I used a tee shirt to clean out the gunk. I didn't want to mess up my dremel. :lol: I also blasted it with some compressed air and got some chunks of grease to blow out of there.
As for the rotor assembly, I sprayed that bottom part down with WD40 and used a toothbrush to clean it. Then I used more WD40 to wash it off, after which I sprayed it clean with the air compressor. It was shiny!
After I made sure everything was clean and ready to go back in, I reassembled everything in reverse order. The window works again! I'm hoping that this lasts a lot longer than the last time. At least now I know that the rotor can be removed and cleaned.
i just want to know if this happened to anyone else....after i did this to my passenger side window this morning right after i assembled it, it worked like a charm. it was actually working better than the d/s one. but the only thing is sometimes it wont work at all and i have to bang in the spot of the motor to get it to work. does it sound like theres a loose wire or something because i cleaned the **** out of it.
Discussion Starter #13
No, that hasn't happened to me. It might need a second cleaning. Take it apart when you have time and check the connections.
Discussion Starter #14
Well, I took it apart again for the 3rd time to clean it. The motor was working great for a little longer after the 2nd cleaning, but it looks like I might have to buy a new motor. For some reason, it won't even work this time.
For those having intermittant operation problems. after you take the motor out there are 2 spring loaded contacts one on each side. clean those with electronics cleaner by spraying, air blasting and pushing them in and out until you have full spring motion. they should come out quite far once clean. then have a fun time getting the piece back in.
QUOTE (mercury9180 @ Jul 27 2008, 02:44 PM) index.php?act=findpost&pid=547642
How did you get passenger side door panel off? I did the driver's side window with no problems but when I tried to take the passenger side door panel off to repeat the procedure I can't get the panel off. It seems like its hung up by the door handle pull. There must be a hidden screw that's keeping the handle in place. I remove the two screws under the passenger side control panel but that last screw is giving me headaches because I can't even see where it is. HELP!
QUOTE (jollyroger713 @ Sep 7 2008, 05:31 PM) index.php?act=findpost&pid=553621
Ok, I figured out how to remove the passenger door panel by following the speaker installation instructions in another thread on this site. I'll paste in the instructions for others to follow in case it helps.
Per "Tutorial:Front Speaker Installation", the passenger door removes in a similar fashion [as the driver door] with one exception, the vertical door handle. Using a small pick tool or flathead screwdriver, carefully pry out the top portion of the aluminum handle covering. Once it is far enough out to get a grip on, pull it off of the door perpendicular to the door panel's surface. This will expose 2 deep cavities that house 2 10mm bolts. Using a 10mm socket and a long extension, remove these 2 bolts. After you have removed the bolts, pull the handle out. It may seem tight, but will come out with a little force. The rest of the door panel removal is the same as the driver's side.
SmoothZ - You missed a tool.....I can't tell you how long I worked on this project until I realized the absentee tool......3 x 12 oz. Mooseheads....may take other users more or less and remember less is more....Muhahaha.....Your pictoral was RIGHT ON! So I can take this project off my list of stuff I can get too....tomorrow! Thanks LT
I do not use spel chec I think it is over rated......Muhahaha
1 - 20 of 63 Posts
