these are pics of my Z after the hotchkis install. the install was harder than expected but it was well worth it. i also put one of my new smoked lights
[attachmentid=12299][attachmentid=12300]
Hello Edwin,
I'm guessing that you installed the Hotchkis Sways and Springs, is this a correct assumption?
Did you find the spring install difficult??
I have a set of Hotchkis springs just waiting to be installed.....
i only installed the springs. it was fairly difficult on the front .. but once you do one side the other one goes smooth. as for the back, its a piece of cake. :cheers:
i smoked my tail lights using nite shades spray and toykillas tutorial. fairly easy process but you need to take your time for everything to come out perfect.
Edwin, how long did the spring install take?
Do you feel a ride/handling difference after the install? If so, can you describe your experience?
BTW, sent a PM regarding the "other" part :biggrin: wondering what you think and your progress :cheers:
I can install a set of springs on the Z in a about an hour. I have done about 4 sets now, but to the first timer, I think it could easily be done in under an hour.
The hotckis setup is about as forgiving as the stock setup - not any harsher. Provides more stability, and less body roll (if you get the sways as well)
