The dream has become reality.
I found this today:
http://www.shh-proshop.com/index.php?optio...21&Itemid=1
Both left and right hand drive kits too!!
Also is featured on the HKS Japan website.
http://www.hks-power.co.jp/
I have translated the specs from the Japanese website using Google Language Tools and this is the result:
Fair Lady Z
HKS, the VQ35 supercharger tune instruments, and a single turbo GT SUPACHAJAKITTO SUPESHARUFURUTABINKITTO of the two types of menus are available with a twin-turbo and many requests from the twin-turbo specifications to facilitate the development of a possible setup kit has been developed.
Features
● Z33 high-power specifications of the request to respond to the turbocharger that came TSUINTABOSETTOAPPUKITTO.
● turbine is response-oriented GT-SS from the almighty of GT2530, high-power shot from the GT-RS select.
● Pure catalyst can be used and the layout.
● setup kit for mounting in the processing and suction piping fabrication of a variety of the CPU involves setting.
Instructions
● F-CON V Pro and control is required.
● GT-SS/GT-RS turbine process is needed.
● fuel pump and injector need to replace.
● maximum torque 490 Nm (50kg-m) more than the specification, the E / G strengthening is required.
● standard actuator configuration supercharging pressure is approximately 40 kPa (0.4kg/cm2)
● only large-capacity oil pan, the amount of oil per liter increase.
● VQ35HR vehicle is not mounting.
● various piping (suction pipe, etc.) separately fabrication is required.
● OIRUINRETTO parts additionally required.
● turbine for the protection of water piping must please.
● exhaust system components around the plate and heat production is required.
● fuel processing line (bending) required.
● starter terminal processing required.
● engine mount HITOINSHURETA Removing the need (Right Bank).
● OIRUKURAKITTO (15004 - AN002) and the combination allowed.
Kit components
● exhaust manifold: casting -
● turbocharger: GT-SS 56T A/R0.64 × 2
GT2530 63T A/R0.64 x 2
GT RS-52T A/R0.64
two of either.
● extension actuator, the bracket: Set supercharging pressure: 40 kPa (0.4kg/cm2)
● CHANBAPAIPU
● Oil Pan: large-capacity type
● Oil Out
● oil Return
Marque Fair Lady Z
Z33 model
VQ35DE engine model
Year 02 / 7 ~ 06/12
STS turbo kit
Turbine size GT-SS 56T A/R0.64
Set supercharging pressure 39.2kPa (0.4kgf/cm2)
No full kit code. 11001-AN002
Retail price ¥ 546,000
(Tax arranged price) (¥ 520,000)
Remark setup kit
Turbine size GT2530 63T A/R0.64
No full kit code. 11001-AN004
Retail price ¥ 609,000
(Tax arranged price) (¥ 580,000)
Remark setup kit
Turbine size GT-RS 52T A/R0.64
No full kit code. 11001-AN006
Retail price ¥ 630,000
(Tax arranged price) (¥ 600,000)
Remark setup kit
