I need help on finding my Intake Air Temperature Sensor or to see if maybe it's called something else.
I just bought a mod chip and the directions state that I need to connect it to the Intake Air Temperature Sensor which should be only two wires and about 5 volts.
I don't believe it's the Mass Air Intake sensor because it consists of 5 wires.
Help.............
What type of mod chip did you buy? I am sure it is not but this isnt one of those ebay 20 hp for 20 dollar jobbers is it? The sensor is usually located in the intake piping and sort of looks like a factory wire connector.
imo, more harm than good. You don't want to tap into the air intake temp sensor and have it send false information to the ECU.
I am not certain, but it may be contained in the 5 wires of the MAF. If not it is upstream on the throttle body.
good luck
I bought the chip off of RaceMod.com and It stated that will will not do anything to ruin the computer but........
If I don't find it soon, I'm just going to send it back.
Thanks for your help.
Good to know........It's going back
Any info. on where I may get a good mod chip or even if It makes a big difference in performance?
