Hi.
my trunk is stuck, when I press the button for release I get a beeping sound, when I try to manually open the trunk the key does nothing. Is there another way off getting in.
thanks.in advance.
Super Moderator
Welcome, but I don't own a ZR. My suggestion is to look for a Nissan tech in your area with ZR experience. Somehow the release cable to your trunk has become detached and you'll need an expert to get in there and repair it.
Hi. Yes my trunk would not open on the button because the roof was in fault. I had to remove the rear bumper and drill a hole behind the latch, I then worked the latch manually and got the lid open.
I found the cable for the emergency key release had come loose so I retensioned it and now I have key entry until I get the roof fixed.
Super Moderator
Glad to hear you got this fixed, but how did you remove the rear bumper without opening the trunk?
