I know, I know, another clunking-popping noise, but help me figure it out. The problem presents during slow speed turns, most noticeable when pulling out of the driveway, for example. The car handles as well as ever, so I don't think anything is broken. I put the Quaife in a while ago (which I suspect has something to do with the problem, but I don't think IS the problem). I am also running the big slicks on the rear, so I know there is a lot of strain on the drivetrain at slow speeds. I recently greased the sway bar bushings, but that didn't seem to do anything.
I SUSPECT this has something to do with the Quaife locking at slow speeds (not causing the noise like a clutch type would) but causing something else to make this pop. I was thinking something like the CV joints... I have read about Quaifes causing the CVs to pop all over the place at slow speeds... and if that's the case, it's fine, I just want to make sure nothing is wrong. The boots on the CVs are in tact, should I try re-greasing them or something?
And just for diagnostic purposes, I first really noticed this after spraying some liquid wrench stop-squeak oil all around on the suspension components for an un-related squeak (solved). I don't know know if this could have started the problem some how? I also made a rebound adjustment at the same time-ish, but I don't think that could have caused anything?
Thoughts are welcome, I'll take whatever help I can get here. I mostly just want to make sure there's nothing I've overlooking that is going to cause catastrophic failure or something...
Thanks!
-willy-
Thanks!
-willy-
