Hey guys, I just got done installing new NGK Double Platinum plugs to replace the factory ones, and installed a Crawford cast plenum. I hooked the coil packs up, put dielectric grease on the plugs, made sure all the vacuum and coolant lines from the plenum were hooked up. I put the nylon washers on and it's all bolted down. We've done it all and taken all of it apart twice now and we can't find the problem. When I crank the car, I have to rev it to about 2k rpms to keep it from dying. If I let it try to idle, it sputters out. If I keep it at 1k rpms it has a really rough idle and barely stays cranked, but when I let my foot off the gas completely it dies. I'm out of ideas. I'm not sure if it could be a vacuum leak anywhere, but we tightened everything down right and it appears to be sealed.
Help! :ahhh: :ahhh:
Help! :ahhh: :ahhh:
