:rolf2: Take lots of before and after pics. I'm curious as to what the damage looks like.im going to give it a shot.. So in the end we are either going to have a new How-To Tutorial , or a How-Not-To-Do Tutorial![]()
What he said....done a few Chevys, not sure about the Z, but would expect similar. Take care not to 'mushroom' the stud beating it out....here's where an air hammer & a round 'chisel' come in handy. If the hub has to come off, you can use a press to press the old stud out & the new in. Simple, yes, but simple ain't always 'easy' :banghead: ....but I'm sure you can get 'er done. :cheers:Killa. Unless the Z is designed REALLY weird .. replacing a wheel stud is easy. The stud is like a big bolt .... uder the 'head' .. the 'neck' has splines. These fit splines in the hole. You basically hammer out the old stud and insert a new one and 'pull' it in. The only real problem is .. depending on the car .. if you have room to get the stud out. Sometimes there is actually a 'cut-out' that you can rotate the hub to in order to remove the stud. Worse case is you have to pull the hub. Think about it .. basically a big flange with holes drilled in it and then splined. Also .. if you are leary of 'tapping' the stud in .. you can use a couple of nuts to 'pull' it in ..
Getting the stud out/in was the easy part. The hard part was that the E-brake blocked the stud from removing. Turned out that the fix was easy .. he managed to move the E-brake out of the way. It is (once you figure out the way around the probs) pretty easy fix and a for-sure DIY.It is an easy fix, just like hammering a nail out of a piece of wood.
:cheers: glad you got it fixed! :yourock:got it fixed! :cheers:
will have a step by step writeup sometime soon.. wasnt all that bad!
