Tell your rental place that you're fixing a flat so you need to remove the tires. I have pics, let me bring the up. Hold up.
Okay, here they are:
I first jacked the car up off the ground with a hydrolic jack I got from K-Mart for $15. I then removed the wheels, which allowed me to then remove the inner wheel well.
To remove the inner fender, I removed 3 plastic clips and about 8 screws. Three screws were holding the inner fender liner to the metal fender at the edge. The 5 others were below the front lip of the car.
To remove the plastic clips. Take a flat head screwdriver and stick it between the plastic corners and gently push the screwdriver under the circular part. You'll be able to pop the clip out with a little movement.
After you unscrew and unclip everything, you have to push the inner fender to the medial part of the car to make it free. After this, you can just let it ly down on the brake rotor. The white circluar cover is what covers the lighting unit and to remove this, turn it the direction that it says.
