1 - 20 of 24 Posts
Hi guys I have a 350z 2004 model with some bolt-ons :nismo exhaust,megan test pipes ,nismo headers ,k&n drop in air filter ,5/16 plenum spacer
,JWT plate & flywheel and the turboXS UTEC .
So what do you think I m able to achieve 280-290 whp with good tuning ??
The problem right now is that with stock Z i m not far enough 1-1/2 car front
whats your opinion about that ??
I m going next week for tuning the UTEC
245 to 250 whp. If your tuner says more than that, he's fudging the numbers. I'm hoping for 280whp and I have every bolt-on plus JWT S7 cams on an '06 Rev-Up.
+1 i8acobra... 245 to 250 whp WITH a good tune.
-Confused- it says 287 bhp. so thats just engine HP not to the wheels?. how much torque does the Z have then?.
I have a JWT popcharger, Motordyne 5/16 plenum spacer, kinetix high flow cats, XO2 true dual exhaust.. so that means im prolly pushing 230 hp to the wheels and 310ish to just the motor??.
ok 245-250 its good numbers but I have seen other Z 's achieve more than 250 with the same mods or less
C this:
1)http://www.youtube.com/watch?v=Xb59cPldECo
2)http://www.youtube.com/watch?v=rBUXuvgcPCs&feature=related
3)http://www.youtube.com/watch?v=vwoZcNdc6fQ&feature=related
4)http://www.youtube.com/watch?v=_Bf9KZTq-Jk&feature=related
I know if i m going to search I will find more dyno charts but all this doesn t mean nothing
Also some of them they have only bolt ons without tuning ecu or UTEC
So I m hoping for better results than 250 what do u say ?
I also think it's possible. I got rated in the range of low 240s from different dyno's. I don't have as many mods as your car, either.
i'm gonna throw out an exact number, JUST THROWING IT OUT, but i'm gonna say you'll be right at 247 :biggrin:
haha...hmmm...a greek sandwich huh?
QUOTE (dionic_5 @ Mar 25 2008, 05:11 AM) index.php?act=findpost&pid=510090
C this:
That doesn't mean much. I can video tape me running my car on the dyno and show you a 500 whp chart right now. Doesn't mean I'm actually making 500 whp, though. It's not difficult to mess with the correction factor to get whatever reading I want. Run the car in the 1/4 mile... Your time tells you how well you hooked up and how good a driver you are. Your speed tells you haw much power the car's making. If you can run a 13.7 @ 103 at sea level in a Z, you're right around 250 whp.
I made 263whp on a dynojet with almost the same bolt on's as the OP. The difference was I have a Borla TD and had a unichip at the time. Now I have a Utec and I know my power has gone up. My car pulls so much harder in every gear.
QUOTE (i8acobra @ Mar 28 2008, 01:31 PM) index.php?act=findpost&pid=511201
I've dynoed from 249 to 281 on different dynos. Bring it to the track.
+1. A dyno only tells you what your car does in one gear. I added an X-pipe muffler to my Borla and noticed an improvement in first through third gear, however my fourth gear pull was the same as before.
1 - 20 of 24 Posts
