If you are going for 350 RWHP only then the fuel system is overkill, you could probably stick with just the fuel pump but still need to tune or change the MAPS and go for around 7 PSI or you might even be able to get that HP at your current PSI with just tunning depending on what other mods you have. The kit comes extremely rich so with you current setup you are probably overly rich which is resulting in your bogging down at higher RPM's.
I would stick with the colder plugs and go with the pressure harness so you can run the emanage off of boost rather than the MAF this will result in a very smooth running car and transition in power when you hit boost.
