Went to the main forum, and there there's a service interval work checklist.
Nowhere could I find a mention of either checking oil levels or change intervals for either gearbox or diff. STRANGE!
I've had the 'box changed @ about 30000k just in case - but where's the recommendation?
FRIZ
Good question! I think you can find the information about the chassis lube points in the service manual. If you don't have the service manual, send me a PM and I can help you out by pointing you in the right direction.
As for the recommended intervals for changing your fluids, I would think that information is located in teh service manual as well. We will have to post up that information. Thanks for pointing it out.
Shizzle, you recall that CD I dropped off to you some time ago with "the run" on it?
You will find on the same disc the service manual, all the info you need "should" be in there somewhere.
If you can't find the disc yell out and I will email you a copy of the manual.
Or, just ring Leigh. Im sure he will tell you.
As always
FASTER :beer:
