1 - 20 of 41 Posts
This past w/e went to fill the tank in the Z, it showed 1/4 tank. At about $12.00 the gas pump clicked off, I knew this wasn't right, I got in the car turned the key to see the gas gauge and it was at 3/4 tank. I continued to fill the Z, but the gas pump clicked off at every $.11 of additional gas. I finally filled it but has this happened to anyone else? Is it common with colder temps??
I looked for a thread but could not find one.
Common issue cold or hot...the Z's gas tank is split so it's a PITA sometimes to fill all the way. Try shaking the a$$ end of the car or turning the gas filler nozzel upside down.
I shook the car, no luck. I'll try the upside down adjustment at the next fillup. Thanks.
That's one problem that I would never have thought existed. :angry:
Why turn the nozzle upside down??
I really don't know why...but this issue has been around since the car was introduced and turning the nozzel upside is an oft posted fix. It may not work everytime or at all, but it can't hurt as long as you pay very close attention to the sound of the gas filling in the tank. Having the nozzel in this position may disable the auto fuel cut-off, and we don't want gas spewing all over the paint so if you decide to try it...be prudent. Sorry I didn't post this disclaimer before.
Be aware that when your fuel low lamp goes on you still have 3+ gallons in the 20 gallon tank, maybe more depending on the shape of the measuring device/relay in the tank.
You could also try pulling the nozzle slightly farther out. Sometimes if not enough air is getting into to tank, the nozzle will shut off to avoid a build up of gas fumes.
Good advice...vapor lock will cause the nozzel to shut down.
I tried that also, it didn't work. :doh:
I've had the Z since early Spring and this is the first time I've had this problem. I did go to a different station, maybe it was their system or nozzle.
i had this issue as well. i ended up taking it to the dealer and they replaced my gauge cluster and that was over 6 mos ago...BUT this wknd it happened again...so i don't know what to do about this
i guess its a cold hot weather issue, first time i hear of it, but maybe cz i have been here in hot FL for a while now.
shaking the ass of the car is a good idea
good luck
<------------------3000 posts
What if I shake my ass? Will that work? :rolf2: Oh and congrats on hitting the 3,000 mark ayman. I see how you did it too. You're as big of a thread hopper as I am. :cheers: Look I've got 30!
1 - 20 of 41 Posts
