I learned over the weekend that the adjustment of this little round panel is somewhat finicky (sp?). However, it's not hard and takes nothing but patience and a philips-head screwdriver. Apparently the 2 little tabs on the inside must rest in the alloted space and need to be centered perfectly for the release button to work properly. I just kept adjusting, closing, eyeballing the panel, then releasing it again to adjust some more.
For a while, I had problems getting that panel opened (probably a bad install from the factory). Now it's all better. It's a little tricky getting the whole panel out but with care it can be done.
I hope this is the correct location for this topic/thread. :goodtimes:
