1 - 2 of 2 Posts
I have an areomotive 340 fuel pump. My question is when I put my finger over the sending unit with the fuel pump that sends it straight to the motor on top of the fuel hat of the car should I get a big spray or very little come out when I try to start the car because my car started for the first time with that Fuel pump for a few minutes and then turned off and will not start again by the way this is a super charge install
Super Moderator
Not familiar with this particular fuel pump, but line pressure should be high from the sending unit. How are you turning on ignition to the VQ35DE if you're holding your finger over it? That sounds like a very iffy situation for checking your fuel pump.
1 - 2 of 2 Posts
