1 - 1 of 1 Posts
Just trying to clean up the surge tank system that the previous owner installed on the car, he used rubber lines for the surge tank and return system which I want to convert to SS lines with AN fittings.
What size is the fuel return fitting that is on top of the fuel pump basket?
I want to buy the quick disconnect AN fittings as seen in the picture below. (the fitting on the top). Just want to make sure I order it for the right size.
If the above question/picture isn't clear, below: looking for the diameter of the 90 degree fuel feed port on top of the fuel pump basket.
1 - 1 of 1 Posts
