Status
Not open for further replies.
1 - 3 of 3 Posts
Rockford Fosgate T5002 used two weeks w/ spec sheet.
Key Features:
» 75 watts RMS x 2 at 4 ohms (CEA-2006 Compliant)
» 150 watts RMS x 2 at 2 ohms
» 250 watts RMS x 2 at 1 ohm
» 300 watts RMS x 1 in bridged mode (at 4 ohms)
» 500 watts RMS x 1 in bridged mode (at 2 ohms)
» 1-ohm stable (2-ohm stable in bridged mode)
» Tri-way capable (Tri-Way Crossover required)
» requires 1/0-gauge power and ground leads — wiring and hardware not included with amplifier
» variable high-/low-pass filters (40-400 Hz, switchable from 12 to 24 dB/octave)
» Para-Punch bass EQ (0-18 dB with variable center frequency between 35-70 Hz) with wired remote control
» MOSFET power supplies and outputs
» MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
» TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
» TRANS-ana circuitry keeps preamp signal clean
» NOMAD advanced protection circuitry monitors temperature, voltage, current and impedence, and provides "intelligent" shut-down protection without limiting system performance.
» fan cooled
» preamp outputs for easy connection to a second amplifier
» fuse rating: 100 amps
» dimensions: 17-15/16"W x 2-11/16"H x 12-3/4"D
» warranty: 2 years
Also check the sheet below this amp puts out WAY more power then it is rated at. 706 watts at 2 ohm and 983 at 1 ohm.
here is the link to crutchfield...
http://www.crutchfield.com/S-6GRKOhCme5G/c...=110&I=575T5002
ASKING $225 + SHIP!!
Next up, Pioneer Premier DEH-P760MP
used for a month. with original box. AND NISSAN WIRING HARNESS! TRUELY PLUG AND PLAY! NO CRIMPING OR SOLDERING REQUIRED!
Pioneer Premier DEH-P760MP - Car Audio In-Dash CD/MP3 Receiver
Supertuner
Supertuner Supertuner IIID
XM Radio Ready
24-Station/6-Button (18FM/6FM) Presets
BSM (Best Stations Memory)
CD Player
1-bit D/A Converter 8fs/16-bit
CD-R/CD-RW Compatible
MP3 Compatible
WMA (Windows Media Audio)
Wave (.wav) Compatible
AGC (Automatic Gain Control)
Disc Title Memory
CD Text CD Text
IP-Bus (Changer Control)
BMX Digital Compression
Audio Section
MOSFET50 (50W x 4-channel High Power)
Equalizer EEQ (3-Band Parametric)
SFEQ
EQ-EX
Source Level Adjuster (SLA)
Loudness 3 Mode
Selectable Fader
HPF Crossover
Subwoofer (LPF) Crossover
RCA Preouts 3 (2V)
ASKING $200 + SHIP OBO IF GOES FOR 200 WILL ALSO INCLUDE NISSAN DIN PANEL
otherwise DIN = 10 dollars. + SHIP
Finally, the last item today is a Line Out Converter. This is used when you want to run Subs off of the stock head unit.
$15 + SHIP
Thanks for your time guys!
Discussion Starter · #2 ·
UPDATE: Pioneer Premier DEH-P760MP Now Sold!
UPDATE: Nissan DIN Sold!
1 - 3 of 3 Posts
Status
