1 - 1 of 1 Posts
Hey guys, new to the forums here, the previous owner of this vehicle was quite active on here though. Without a doubt the best car I've ever owned. Featured in StreetCover (FEATURE – HENDRICK’S NISMO INSPIRED 350Z | STREET COVER). Brand new Heavy Duty Exedy Clutch, and Custom Built 2000W Pioneer Sound System ($~7000). Never had a problem with it, selling as I have a new project. The ad with contact details and photos is up on BoostCruising here: 2003 Nissan 350z Track Z33 for Sale | QLD: Brisbane South
No engine issues whatsoever, car computer has recently been refurbished and works perfectly, bumpers and skirts have just been repainted.
Tuned with Motec to achieve 8200rpm
Performance Modifications:
- Engine Internals:
o Nizpro Spec 11.5:1 Forged Pistons (By Special Piston Services)
o 0.008 overbore
o Moly coated piston skirts
o Nissan 0.2mm overbore piston rings
o Carrillo A-bean (I-bean) ultra lightweight connecting rods
o Carrillo connecting rod bolts
o Balanced short block
o Over bore and hone 6 cylinder strainer plate
o Nizpro modified bearings
o Nizpro modified oil routes
o Nizpro modified cylinder heads
o Nizpro modified combustion chambers
o Nizpro modified injectors
o Nismo Spec 1 Intake Camshaft (276 degree, 11.0mm lift)
o Nismo Spec 1 Exhaust Camshaft (256 degrees, 10.5mm lift)
o Nismo VTC Pulleys (55 degrees)
o Nismo Oil Pump
o Ferrea competition plus light weight intake valves
o Ferrea competition plus light weight exhaust valves
o Ferrea titanium retainers 6 degrees
o Ferrea dual valve springs
o Ferrea steel valve locks
o Ferrea valve seals
o Ferrea valve seat locators for Ferrea valve guides
o Ferrea copper exhaust valve guides
o Ferrea manganese bronze intake valve guides
- Intakes:
o Nizpro 84mm intake pipe with integrated MAF sensor to Nismo specifications.
o Nizpro spec larger bell mouth intake integrated in the stock airbox
o K&N high flow replacement filter
o 05 350Z lower plenum (with shorter runners and larger intakes)
o Motordyne Engineering 5/16 Plenum Spacer
o US Spec 350z larger intake airbox duct
- Exhaust:
o Fujitsubo SuperEx stainless steel header set
o Nizpro 3 high flow catalyst converters
o Nizpro Spec Y-pipe with larger collectors
o Nismo RS concept titanium centre pipe
o Nismo RS concept titanium (with a Z logo) rear muffler
- Drive Train
o Nismo light weight flywheel
o Fluidampr silicone fluid harmonic damper
- Engine Management System (ECU)
o MoTeC M600 ECU
o MoTeC Cam Control Module
o Nizpro Plug & Play MoTeC wiring loom for 350Z
o Redline and fuel cut: 8000/8200 rpm
- Engine cooling:
o Motordyne iso-thermal throttle body coolant controller
o Motordyne iso-thermal lower plenum gasket
o Nismo Fuel cap
- Traction Control:
o Traction Control kill switch (disable factory traction control completely)
- Others
o NGK platinum spark plugs
o Apexi earthing kit
Exterior Modifications:
- Body Kit:
o Nismo version N1 Version II front bumper (JDM)
o Nismo Canards
o Bonnet Bulge upgraded from 07+ Fairlady (Aggressive look)
o Topstage side skirts (JDM)
o Nismo rear under pods (JDM)
o Nismo version rear spoiler (JDM)
o Nismo Carbon Fibre B-Pillar Trims
- Wheels:
o Nismo LM GT4 front wheels (8.5J x 18)
o Nismo LM GT4 rear wheels (9.5J x 18)
- Suspensions:
o Tein Super Street Height Adjustable Coilover kit.
- Interior Modifications:
o Alpine Headunit with Customised CarPC with SatNAV
o Nismo Floor Mats
o Nismo 8000rpm/320km/hr tachometer
o Nismo GT titanium gear knob
- Brake:
o Hawk HPS front pads
o Ferodo DS2500 rear pads
o DBA 4000 slotted disc brakes front and rear
o Motul RBF600 brake fluid
o OEM 350z Track Brembo Calipers
- Sound System
o Custom Engineered Subwoofer Enclosure
o Twin Shallow Mount Pioneer TS-SW2501S4 Subs
o Pioneer GM-D8500M 1200W Amplifier (Subs)
o Pioneer GM-D9500F 800W Amplifier (Speakers)
o 2 x Pioneer TSD1720C 520W Component Speakers
o 2 x Pioneer TS-D1602R 520W Split Speaker
1 - 1 of 1 Posts
