1 - 10 of 10 Posts
So the spring out cupholder in the dash on the passenger side seems to be stuck or unspringable or whatever. I can pry it out a little, but it gets stuck somehow before coming out all the way. Clearly, I don't wnt to force this without looking behind it and seeing wtf is goin on.
Anyone know the best way to remove this?
Discussion Starter #2
QUOTE (jgruberman @ Jul 27 2009, 05:51 PM) index.php?act=findpost&pid=581023
I take it back. Remove the kickpanel and there's one screw, then it just pops off. :)
Ouch......shitty interiors.... :banghead:
My best and only advice would be to suggest possibly getting the cup-holder as far open as you could, then spraying a little WD-40 in there to possibly lube up what ever is stuck. Funny, with all the phantom rattles, clanks, and other weird happenings with my interior, that little cup-holder has always worked. I probably just jinxxed it.
edited for spelling....
How are you trying to get it to release? Are you pushing it IN to get it to pop out? That is the way it opens, by pushing it in it releases the lock somehow..... It's also quite possible that whomever owned the car before you let something spill on there, if that's the case it could be sticky and just stubborn to come out....If you are pushing it IN to get it to release, can you get a finger in there? If you can try pushing down on the center part gently, see if that helps it pop back out, the middle cup holder part needs to go down to get it to fully "engage" or lock in the out position.....I wouldn't try prying it out unless you want to break it....I'll go onto my desktop and see if there is a diagram in the SM or in the owners manual, I'm on the hubby's laptop right now....so if you can hang out for a minute I'll see what I can find.
Discussion Starter #6
No, but I appreciate all the speedy responses.
It's not that it's stuck... but I push in to release the lock and it just kinda sits in. If I give it a bit of a "jolt", then it will come out a little bit, but not nearly CLOSE to being a cupholder. Then if I give it a little pry(when its already suposed to be in the "out" mode), it pops out about halfway.
But when I pulled the dash piece off, it all of a sudden popped out. So I tried pushing it in and out and it worked fine. I put the dash back on and pushed it in again and it struggled to come out. It's almost as if something is there that is holding it in, like a "bend in the plastic" somehow but the dash hasn't changed. The cupholder DID work when I got it originally and it just stopped. It HAS been raining a lot lately so maybe it's the humidity that softened the plastic or something. I popped it back out, put WD40 back in there and it seemed to work okay for a bit. Now I at least know its really NOT broken, I can come back to it later if I have the problem.
Next fire to fight.... the open gastank button that pops out of the hole into the dash when I push it too hard(which I either have strengthened myself vastly, or its weak/loose because I'm not pushing hard). Yes, I know the interior is falling apart lol
Jguberman. Although WD 40 is safe to use on plastic, it doesn't provide very good or long lasting lubricating properties between plastic parts. You will have a lot better results using a silicone spray product. There is a reason silicone is used in premium sex lubes, it's super slippery! That same quality makes it ideal for use on plastic and rubber parts.
Mine has never worked. Four years now...I gave up. It's the only thing I have not been able to fix. :cry:
Discussion Starter #9
QUOTE (IDrm350 @ Jul 27 2009, 11:10 PM) index.php?act=findpost&pid=581048
Come do the body work on a body kit for me and I'll fix your cupholder :rolf2:
1 - 10 of 10 Posts
