I have a chance to purchase a set of Factory Brembo brakes, front and rear off of a G35. I was wondering what I would need in order to have them installed and work on my base model 350z. I am only picking up the actual rotors and calipers for all four corners. What else do I need to complete this conversion? Also, what is a good price for a set of slightly used brembo G35 rotors and calipers, front and rear? I am only considering this route because I think it will be cheaper than going with the gran tourismo big brake kit from Brembo. Any advice on this matter would be very helpful. Thanks
As long as you have the mounting brackets from the G35, too, you shouldn't have a problem. I've seen used Brembos go for $2,000-$2,500 (basically new for the latter price).
Edit: I've heard that the Brembos will fit inside the stock 17" wheels. But don't quote me on that.
The Brembos will fit inside the OEM 17" wheels for the Z only. The 17" G35 wheels do not clear the caliper.
