I have a set of eyelids that just wot stay on. I have been using 3m stong tape but it just isn't helping. Is there anything out there I can use that will keep these guys on and be able to hold when it rains?
what kind of eyelids are you talking about? biggest thing when using 3M tape is to make sure both areas to be contacted with are clean and dry. rubbing alcohol does that very well. Then use the Acrylic plus tape. that stuff is like iron. I used that for my central 20 headlight covers and they have not budged at all
I had the same trouble with my eyelids, I ended up using this red double sided tape from 3M, it is supposedly the strongest double sided tape you can buy and is rated at like 7 pounds per strip or something like that. Anyway, 3M red double sided, good luck.
