im sure every bolt is different.. if you look in the service manual there are torque callouts on pretty much every bolt.. i guess find the bolts you think you may need to torque and look up the specs in the manual
7? Are you sure about that jinxx? Hondas are rated somewhere in the 40 - 50 ft lbs range. The lowest air ratchet I saw put out 20 ft lbs, and that one was extremely weak compared to the rest.
Well, that's what we did for the grounding kit, I am not really sure about the exhaust but reading an install article it says 32-35# of torque for the Borla clamps and pipe flanges...
