I have recently installed headers and test pipes, and I keep on getting the same code every few days. So I hook up Digimoto to see what it is, it gives me P0420. Does anyone have any input to what this is and how can it be resolved?
Originally posted by BluZee@Dec 8 2004, 01:23 PM
Three way catalyst function, bank 1. "Catalyst system efficiency below threshold". That would make sense since you dont have the cats anymore.
Originally posted by Jetpilot718+Dec 8 2004, 01:48 PM--><!--QuoteBegin-BluZee@Dec 8 2004, 01:23 PM
Then wouldn't it be ABOVE the threshold? As in really efficient! heh
But seriously nemesis, have you reset your ECU?
Originally posted by LuKsEaZy@Dec 8 2004, 04:06 PM
basically he said if you have no cat then that code will come on....
Originally posted by LuKsEaZy@Dec 8 2004, 06:06 PM
hey i justed asked a technician were I work at (nissan dealership) what the code was. He said this the 1st oxygen sensor sends a single to the ECM to tell how much fuel to send to the motor then the 2nd O2 sensor read the fumes coming from the Cat and sends a single back to the ECM
1st 2nd
___/\_____________/\___
/--->--------FLOW--------> \
\______________________/
yes i am bored at work.....shut it
basically he said if you have no cat then that code will come on....I can't explain it for those whos light haven't come on yet...(and they have no cats either)....but that is what the code means
You can reset the ECU but it WILL NOT help at ALL!!!!
Originally posted by jinxxycat@Dec 9 2004, 02:07 PM
Here is a post originally made by Tere on ZCHickz.....might help....
For anyone who is interested, here is the "Atari" method of resetting your ECU -- it also clears the codes if you have a Check Engine Light (CEL) you want to turn off.
