1 - 2 of 2 Posts
Just dyno'ed my car today on a Dyno Jet 266.28 hp & 230.48 ft-lbs on 4th gear.
I left the place then it came to my mind, did he turn traction control off?
Would it make any difference with traction control on/off?
The first two graphs were jumping around in the torque, hp stayed steady but traction contol never crossed my mind, the guy was actually looking for different hook up points I believe and it was my first time doing this so I didn't think much of it until now..
I'm wondering how accurate this was...
traction wont make a difference in 4th gear.... least not for that kind of power.
This is a dyno jet which tend to run higher numbers, but listing your mods would prove a more helpful way for others to compare to what you have. If you continue to use the same dyno, then adding things can accurately gauge the "gains" you obtain for each item
1 - 2 of 2 Posts
