I’ll open it up in a bit and check it out, thank you !Welcome, and you'll need to remove the DS door panel to inspect the actuator rods inside. One of the rods has probably come loose and will need to be reconnected to the door lock. Do a search on utube and you'll find some visual instructions on this, or have it done by a pro.
