1 - 15 of 15 Posts
hello...
im new here, im planning on buying a 350z for track use, but i "heard" some stuff about the 350 that made me have doubts on purchasing it. the 350z is an absolutly beautiful car and well engineered, but i hear that the drive-by-wire makes it almost impossible to mod the engine? i am planning on twin turboing, but i heard i won't be able to because of the drive-by-wire? is there a way to eliminate it? what makes the drive by wire a problem to modifying the engine and tuning it? some helpful info please! thanks.
tammy.
:thatsfunny:
hello...
tammy.
Drive by wire is an option for Gagnstaz in a drive by :shoot2:
Drive by wire has nothing to do with modding. It merely represents the means by which throttle inputs are conveyed to the throttle body. conventional is direct manual linkage (ie, cable). Drive by wire is electronically linked. Hope this helped!
And Welcome to the Tech!
Exactely, and that makes for a faster throttle response.
Actually, the software for the drive-by-wire limits the throttle opening speed, making it slower to reach WOT than with a direct connection. Not a bad thing - those with a lot of varied high-performance driving experience know that simply flooring the throttle is not always the way to go the fastest..... :burnout:
hello...
tammy.
this person is a moron :doh:
Now, now, all questions should be taken objectively before passing criticism.
I would be interested in an alternate method to eliminate drive by wire. I am having throttle control issues with my throttle position sensor, I am probably going to replace it because the car does not drive smooth.
Drive-by-wire can be a very good thing. But like other relatively new bits of technology, it can be misunderstood. In the case of the VQ35DE as fitted in our beloved 350Z, the DBW is used to provide a very linear throttle response. Far more linear than the engine would be with a standard mechanical linkage.
-RZ
1 - 15 of 15 Posts
