Wheels: Volk TE37
Lugnuts: McGard Spline Drive, closed-end
Can I just use OEM torque spec or do these additions change things enough to use a different torque spec?
What do you folks torque to for your aftermarket wheels?
Thx
-Smoky
Since the torque is really just a measure of bolt (stud) stretch, use the factory specs if you didn't change out the studs.
stock torque spec is fine.
I have used Kyokugen in the past (and still do on the MR2) No bad experience here.
You can always get some Rays lugs.
I've got a set of McGard spline drive (see first post). I'll report back on how these perform. I don't believe in lightweight lug nuts (why skimp for weight on something so important, ya know?). Hopefulyl the McGard will be a good combination of reliability, functionality, and security.
I agree. I suspected it may be more dependent on the studs that the stuff being sandwiched between the hub and lug nuts. Thx!
-Smoky
