Originally posted by Daking350Z@Feb 10 2004, 06:14 PM
OK..New game plan...I **** canned the Perfect Power SMT6 install and will be going down to Altered Atmosphere in MD next Friday to get the ECU reflash with a larger fuel pump and injectors..The DFMU will be gone at that point..As far as cooling,I plan on adding an Oil cooler to keep internal engine temps down and eventually a radiator for further cooling..I think once I hit 425hp I will give it a rest for a while..
Originally posted by booger+Feb 11 2004, 09:05 PM-->QUOTE (booger @ Feb 11 2004, 09:05 PM)<!--QuoteBegin-Daking350Z@Feb 10 2004, 06:14 PM
How come you are not going with the Perfect Power ? Didnt you get it to work right? It seemed like a salution .Have been following your posts to see if it worked out.If it did I was planning on going that route for F/A and timing management .Liked the idea of 2 seperate programs
Originally posted by Daking350Z@Feb 11 2004, 09:34 PM
You N/A??Call Technosquare they have lots of combos of pre programmed ones..
