these hood shocks are great!!! i was really pumped after installing these. the Z should have come with hood shocks from the beginning. anyway, the install on these was way easy! only four total holes (11/64th) need to be drilled. the most time consuming part was cutting the trim pieces around the brake and battery covers. accurate stencils are provided for all cuts as well as very detailed instructions and (4) pieces of black trim. filler plates are optional i think? the filler plates close off the hole that is made when the trim pieces are cut. btw, mine are not installed in the pics below. after install, an adjustment might be needed. i had to make no adjustments, my hood shuts fine and alignment was fine. anyway, this is a great product and worth every penny i spent. the tein shocks are an ugly green that doesn't go with anything in a Z's engine bay. plus they are a lot more expensive. anybody interested in these contact matt at [email protected]
here are some pics!
Hood Opened
here are some pics!
Hood Opened
