Hi people, need some advice, not long bought a gt4 non runner, found that the crankshaft pulley has fractured and threw out the woodruff key into space! My question is that I have got new genuine timing chain kit, fitted the woodruff key into the crankshaft, pushed the new sprocket over the key to the back of the crankshaft, but there's only about 5-6mm of the keyway in the sprocket, is there a spacer or washer that goes behind sprocket? The key also has to drive the front pulley also, it is a small key to drive everything I think, bad design /engineering if that's how it is given the timing chain issues these have, your comments and advice would be appreciated, thank you 👍
