Okay, so.. I just redynoed my car today after to see hp/tq differences between stock and with an exhaust and at first it seems as if I lost 2-4 hp and about the same amount of torque but then after altering idk what it now shows that I've gained about 5hp and 4 tq to the wheels..The correction factor corrects to sea level at a set temperature and humidity. SAE correction tends to be more accurate than Standard (STD) correction. The uncorrected number tells you how much you car is actually making in your location at the time of the run. Smoothing smooths out spikes in the dyno chart. It has nothing to do with the function of the dyno, only how your chart is displayed and printed. A high smoothing factor is good for showing your buddies, a low SF is best for tuning. It's easier to see inaudible detonation with a low smoothing factor.
I compared my previous dyno chart to the one I got today from a the same dynojet and the only differences are humidity, temp and STD... the std on my stock chart was 1.02 and temp and humidity were lower then it was today. Today's chart was higher temps/humidity and a 1.03 STD.. Now, would that BS my numbers?
